Hello, this is something our team is stuck on although it seems like it should be simple even for a rookie team like us.
After last years competition we are having trouble changing the IP address of the router back to the original address. It is still set on the IP address of the competition and we can no longer drive our robot wirelessly with setting it back.
My suggestion would be to reset the router (just like you do at competition before imaging) with a paper clip, then follow the normal control system setup instructions to configure it.
Edit: or turn the security off as the previous poster said.
Just do a hard reset (using the paperclip to hold the reset button in until the router’s lights blink like 1 or 2 times)… Then the access point should default to “dlink” or something like that. The IP to connect to it is like 192.168.1.1. Hope this helps.
I’m pretty sure it defaults to 192.168.0.50, but it should say on the bottom of the box. And again, a reset isn’t going to help unless the switch is physically in AP mode.
