SF and RM
Hi everybody.
I bought CMUCam2 and I want to ask you two questions.
Firtst, when I am sending the ‘SF’ command, is there a way to see the form of F-packets and make the non-visible ASCII characters visible?
Second, what means raw bytes packets? I can’t understand the meaning from the manual. Can you give me an example of raw modes?
I would appreciate any help.
Thank you in advance…
NM
if you want to look at some good code for the camera look at kevin’s code (www.kevin.org/frc). His code is great, even if you don’t use it.
Kevin Watson also has the PDF datasheets that have alot of info. Ill pull out my CMUCam and see if i can answer your question.
Take a look at this thread for more about the format of SF packets.
A theoretical ASCII packet would look like this:
X 54 42 35\r
While the equivalent Raw mode packet would be:
X\x36\x2A\x23\r
It allows you to write simplier serial drivers because each byte is the value, not some character that represents a part of the value.
