For Team 696, I built a 12-station battery cart in 2016 using two AutoMeter BusPro-660 chargers.
These chargers have an extra outlet wired in to plug in another charger, and each charger has 6 channels of AGM optimized 5-Amp charging with prominent red and green lights. There are no buttons or controls of any sort, which was a design spec we made mandatory for our battery charging setup. These chargers simply just work. When designing this cart in 2016, I researched literally every available battery charger on the market, until I reached the end of the internet. This is the charger we settled on. The DualPro RS3 triple-bay black and green charger was also a strong contender, but we would have needed four of those, and would have needed additional distribution (power strip) for the 120V supply to them. On the AutoMeter chargers in this cart, the status lights are spaced apart similar to how the batteries are spaced apart, so it is very easy to see what the status of any particular battery is, without playing the “follow the wire” or “see what happens when we unplug this one” game. This is a problem you have with the DualPro RS3, in it not always being immediately obvious which indicator light goes to which charging output. Aside from whatever the lights say, we follow a strict protocol of qualifying all batteries that go into the cart to competition, and then using them in order. First match gets battery number 1. Second match we play gets battery number 2, so on and so forth. This ensures even wear across the batteries and ensures that we rarely ever play the same battery twice in one day. We typically have 8 competition batteries and 4 practice batteries. So, batteries 9 through 12 are reserved for testing in the pits, compressing air tanks prior to matches, and practice field use; they are never used in competition matches. We typically populate slots 9 through 12 with KOP batteries, which are lower performing than the MK batteries we use for competition matches.
The cart is a rugged powder coated welded steel frame with heavy-duty genuine Colson casters (two fixed, two swivel with brakes) and mounted SB50 housings. This cart has traveled all over the country with us between Houston, Arizona, Las Vegas, and up and down California, through many rough parking lots and driveway thresholds. It has been in and out of our trailer countless times through 5 seasons, and we’ve never had an issue.
We usually wrap it with a moving blanked and stretch wrap prior to trailer transport. Due to the total weight of approximately 300lbs, we train students in special handling procedures for this cart. They know if they manage to tip it over, they will be looking for a new team to join. We’ve never tipped it. One competent student can handle this cart on flat ground. We assign two students to handle the cart on inclines.
With all that said, this cart is not for everyone. It’s about a $2500 cart. But, it has served us well.
If I were building a new charging setup today, and I was okay with a 4-Amp rate, I would strongly consider a bunch of this charger. I’m not fond of the buttons, but it does default to 12V lead acid charging, and the buttons to require a hold to change modes. So, you’ll never need to use the buttons.
