Our team has never had good luck with chain for the drive train. Starting with our 2012 (2011 was our rookie year), we found that belts were lighter, easier to work with, more reliable, less service and maintenance, and seemed to accelerate better. Yes, you do have to have your centers right, but Gates and many others have great calculators to do that.
In 2014, we put our belt drive train inside the tubing. WHAT a difference! The drive train was absolutely fantastic. The mistake we mad was using 9mm wide belts and they did stretch little, but in aggressive negotiations in a defensive manner, they would strip teeth.
In 2015, we use large tubing so that we could use 15mm wide belts and never looked back. Zero issues. Durable. Reliable.
In 2016, due to going over the defenses, we used two sheet metal plates separated by standoffs so that we could put in an eight wheel drive kinda like the Army’s Striker (we feel the Army copied our robot). This chassis was unbelievably durable and reliable, as we dropped tested the robot from 3 feet and it kept on ticking. Our chassis was king this year!
In future years, we plan on going back to the belts in the tubing unless the game dictates otherwise, such as swerve or rugged terrain.
A waterjet should be able to cut through the 1" x 2" tubing. However, using 1" wide tubing means 9mm belts; I would recommend 1-1/2 x 2 or 1-1/2 x 2-1/2 so that you can put 15mm wide belts inside and if you are worried about weight, put in relief pockets in the tubing to lighten it up. Don’t put holes in it where debris can get in, just thin sections from the 1/8" down to 1/32" thick. It looks cool and protects the parts inside.
One last thing. You can buy sprocket material in logs, cut them to length and bore out what ever size hole you want. A typical log is about $80 and you can get 6-8 sprockets out of it. Well worth it.
Any questions, contact us at theflyingtoasters.org
