Hey all 1706 here,
The student programming lead and I this year had many teams come ask about our shooter code and how we got shoot while moving working.
Currently the student programming lead is working on throwing together a whitepaper to share how we kind of started programming our shooter from the beginning to where we ended up after the STL regional.
Because many teams had questions I thought I would just do a quick “dump” of the code from our ShootWhileMove Command. Once the rest of our code is “cleaned up” and ready we expect to do a full code release.
public class ShootWhileMove extends CommandBase {
private final Shooter m_shooter;
private final Turret m_turret;
private final Drivetrain m_drive;
private final ShooterHood m_hood;
private final boolean m_updatePose;
private final ColorSensor m_color;
private final XboxController m_driver;
private double m_wrongBallTime;
private final Timer m_timer = new Timer();
private static Point2D[] m_shotTimes =
new Point2D.Double[]{
//(dist,time)
new Point2D.Double(105,0.82),
new Point2D.Double(135,0.82),
new Point2D.Double(165,0.85),//
new Point2D.Double(195,0.85),
new Point2D.Double(250,1.05),
private static LinearInterpolationTable m_timeTable = new LinearInterpolationTable(m_shotTimes);
private static LinearInterpolationTable m_hoodTable = ShooterConstants.khoodTable;
private static LinearInterpolationTable m_rpmTable = ShooterConstants.krpmTable;
public ShootWhileMove(Shooter shooter, Turret turret, Drivetrain drive,ShooterHood hood, boolean updatePose, ColorSensor color, XboxController driver){
m_shooter = shooter;
m_turret = turret;
m_drive = drive;
m_hood = hood;
m_updatePose = updatePose;
m_color = color;
m_driver = driver;
addRequirements(shooter, turret, hood);
public ShootWhileMove(Shooter shooter, Turret turret, Drivetrain drive,ShooterHood hood, boolean updatePose, ColorSensor color){
m_turret = turret;
m_drive = drive;
m_hood = hood;
m_color = color;
m_driver = new XboxController(4);
@Override
public void initialize(){
m_turret.enable();
m_turret.trackTarget(true);
m_timer.reset();
m_timer.start();
SmartDashboard.putNumber("SetHoodAdjust", 0.0);
SmartDashboard.putNumber("SetShotAdjust", 0);
SmartDashboard.putBoolean("Adjust Shot?", false);
m_wrongBallTime = Double.NEGATIVE_INFINITY;
@Override
public void execute(){
double currentTime = m_timer.get();
boolean wrongBall = m_color.isWrongBall();
if(wrongBall){
m_wrongBallTime = currentTime;
SmartDashboard.putNumber("Current Time", currentTime);
SmartDashboard.putBoolean("Wrong Ball", wrongBall);
SmartDashboard.putBoolean("Shooter Running", true);
FieldRelativeSpeed robotVel = m_drive.getFieldRelativeSpeed();
FieldRelativeAccel robotAccel = m_drive.getFieldRelativeAccel();
Translation2d target = GoalConstants.kGoalLocation;
if(currentTime <= m_wrongBallTime+0.100){
target = GoalConstants.kWrongBallGoal;
Translation2d robotToGoal = target.minus(m_drive.getPose().getTranslation());
double dist = robotToGoal.getDistance(new Translation2d())*39.37;
SmartDashboard.putNumber("Calculated (in)", dist);
double fixedShotTime = m_timeTable.getOutput(dist);
double virtualGoalX = target.getX()-fixedShotTime*(robotVel.vx+robotAccel.ax*ShooterConstants.kAccelCompFactor);
double virtualGoalY = target.getY()-fixedShotTime*(robotVel.vy+robotAccel.ay*ShooterConstants.kAccelCompFactor);
SmartDashboard.putNumber("Goal X", virtualGoalX);
SmartDashboard.putNumber("Goal Y", virtualGoalY);
Translation2d movingGoalLocation = new Translation2d(virtualGoalX,virtualGoalY);
Translation2d toMovingGoal = movingGoalLocation.minus(m_drive.getPose().getTranslation());
double newDist = toMovingGoal.getDistance(new Translation2d())*39.37;
m_turret.aimAtGoal(m_drive.getPose(), movingGoalLocation, false);
if(SmartDashboard.getBoolean("Adjust Shot?", false)){
m_shooter.run(ShooterConstants.krpmTable.getOutput(newDist)+SmartDashboard.getNumber("SetShotAdjust", 0));
m_hood.run(m_hoodTable.getOutput(newDist)+SmartDashboard.getNumber("SetHoodAdjust", 0));
else{
m_shooter.run(m_rpmTable.getOutput(newDist));
m_hood.run(m_hoodTable.getOutput(newDist));
if(currentTime > 0.250 && Limelight.valid()){
double dL = Limelight.getDistance()*0.0254;
double tR = m_drive.getGyro().getRadians();
double tT = m_turret.getMeasurement()-Math.PI;
double tL = -1.0*Limelight.tx();
Pose2d pose = calcPoseFromVision(dL, tR, tT, tL, GoalConstants.kGoalLocation);
if(m_updatePose){
m_drive.setPose(pose);
if(m_turret.desiredInDeadzone()){
m_driver.setRumble(RumbleType.kLeftRumble, 1.0);
m_driver.setRumble(RumbleType.kRightRumble, 1.0);
else{
m_driver.setRumble(RumbleType.kLeftRumble, 0.0);
m_driver.setRumble(RumbleType.kRightRumble, 0.0);
@Override
public void end(boolean interrupted) {
SmartDashboard.putBoolean("Shooter Running", false);
m_turret.trackTarget(false);
m_turret.disable();
m_turret.stop();
m_shooter.stop();
m_hood.stop();
m_timer.stop();
private Pose2d calcPoseFromVision(double dL, double tR, double tT, double tL, Translation2d goal){
double tG = tR+tT+tL;
double rX = goal.getX()-dL*Math.cos(tG);
double rY = goal.getY()-dL*Math.sin(tG);
return new Pose2d(rX,rY, new Rotation2d(-tR));
Not sure if its the most precise method (just learned about pose estimator classes earlier this afternoon) but we had good luck and were able to, at times, shoot while moving at over 3m/s which was pretty cool. Things will only improve more as some of our younger programmers have some really cool ideas I want them to mess around with once we get our robot fixed back up after those tough (but so so fun!) Einstein matches.
If you have any questions please feel free to reach out!
