Hi, I’m recieving the Start Competition error and was struggling to find the root of it. I can compile and deploy the code with no issue to the Roborio, but once it’s enabled I receive this error:
ERROR 1 The startCompetition() method (or methods called by it) should have handled the exception above. edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:386)
at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:453)
at frc.robot.Main.main(Main.java:23)
My code proceeds as follows below:
package frc.robot;
//import Libraries from WPI
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.motorcontrol.Talon;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.XboxController;
private static final String kDefaultAuto = “Default”;
private static final String kCustomAuto = “My Auto”;
private String m_autoSelected;
private final SendableChooser m_chooser = new SendableChooser<>();
private DifferentialDrive m_roboDrive;
//initialize Motor Controllers
private Talon RightHoof;
private Talon LeftHoof;
private Talon Spitfire;
private Talon ShooterOne;
private Talon ShooterTwo;
//initialize Various Numerical Plug-in Values
private double LeftStickSpeed;
private double RightStickSpeed;
private double Fire = 1.0;
//initialize Xbox Controller
private XboxController Pilot;
@Override
public void robotInit() {
m_chooser.setDefaultOption(“Default Auto”, kDefaultAuto);
m_chooser.addOption(“My Auto”, kCustomAuto);
SmartDashboard.putData(“Auto choices”, m_chooser);
//intialize Motor Controllers
RightHoof = new Talon(1); LeftHoof = new Talon(0);
ShooterTwo = new Talon(2); ShooterOne = new Talon(3);
//intialize Controller Input
Pilot = new XboxController(0);
m_roboDrive = new DifferentialDrive(LeftHoof, RightHoof);
@Override
public void robotPeriodic() {}
@Override
m_autoSelected = m_chooser.getSelected();
System.out.println("Auto selected: " + m_autoSelected);
@Override
switch (m_autoSelected) {
case kCustomAuto:
break;
case kDefaultAuto:
break;
default:
break;
@Override
public void teleopInit() {
//prepare Speed Values for Usage by Pilot
LeftStickSpeed = 0.0; RightStickSpeed = 0.0;
RightHoof.setInverted(true);
// soon to remove
RightHoof.setSafetyEnabled(false);
LeftHoof.setSafetyEnabled(false);
@Override
//setup Stick Functionaility for the Drivetrain
RightStickSpeed = Pilot.getLeftY(); LeftStickSpeed = Pilot.getRightY();
m_roboDrive.tankDrive(LeftStickSpeed, RightStickSpeed);
//setup Y Button for Raising Hook AND setup A Button for Retracting Hook
//Current Status: Unknown | LIVE
if(Pilot.getAButton()==true){ShooterOne.set(1.0);} else if (Pilot.getYButton()==true){ShooterOne.set(-1.0);} else {ShooterOne.stopMotor();}
if(Pilot.getAButton()==true){ShooterTwo.set(1.0);} else if (Pilot.getYButton()==true){ShooterTwo.set(-1.0);} else {ShooterTwo.stopMotor();}
//Current Status: Not Functioning to Expectations | DISABLED
//if(Pilot.getAButton()==true){Horns.set(1.0);} else {Horns.stopMotor();}
//if(Pilot.getYButton()==true){Horns.set(1.0);} else {Horns.stopMotor();}
//setup X Button for Firing Note from Shooter AND setup B Button for Loading Note into Shooter
if(Pilot.getXButton()==true){Spitfire.set(Fire);}
if(Pilot.getXButton()==false){Spitfire.stopMotor();}
/** This function is called once when the robot is disabled. */
@Override
public void disabledInit() {}
/** This function is called periodically when disabled. */
@Override
public void disabledPeriodic() {}
/** This function is called once when test mode is enabled. */
@Override
public void testInit() {}
/** This function is called periodically during test mode. */
@Override
public void testPeriodic() {}
/** This function is called once when the robot is first started up. */
@Override
public void simulationInit() {}
/** This function is called periodically whilst in simulation. */
@Override
public void simulationPeriodic() {}
What can I do?
