I’ve noticed on several occasions where I use the buttons available when I post so I don’t have to type the vBcode that sections of what I had typed disapeared. It does it after a return, and removes up a few returns. So if I hit enter, type enter, typ and try to insert a url link using the button, it would remove the text after this paragraph.
Also, right when this was a fresh vB install, they worked fine, and even inserted into the document where the flashing-bar-thing-that-the-type-shows-up-at is, rather then at the end as it does now.
Wetzel
