Here’s a small snippet of code:
@Test
@Order(5)
@DisplayName("Test if robot can turn left using PID drive")
public void turningLeft() {
// Hardcode NAVX sensor return value for angle
when(m_navx.getAngle()).thenReturn(0.0);
// Try to turn left
m_driveSubsystem.teleopPID(0.0, -1.0, 1);
// Verify that left and right motors are being driven with expected values
verify(m_lMasterMotor, times(1)).set(ArgumentMatchers.eq(ControlMode.PercentOutput), AdditionalMatchers.eq(0.0, DELTA),
ArgumentMatchers.eq(DemandType.ArbitraryFeedForward), AdditionalMatchers.gt(0.0));
verify(m_rMasterMotor, times(1)).set(ArgumentMatchers.eq(ControlMode.PercentOutput), AdditionalMatchers.eq(0.0, DELTA),
ArgumentMatchers.eq(DemandType.ArbitraryFeedForward), AdditionalMatchers.lt(0.0));
What I want to see is the arguments that were passed into m_lMasterMotor.set()
and m_rMasterMotor.set()
when they pass the unit test. Right now, I can only see the values when I temporarily purposely change the test to make it fail, and then VSCode shows me the actual argument values vs my expected ones.
