Would anyone be able to tell me why shuffleboard isn’t displaying the colors in the boxes for my widget. I have tried to follow Shuffleboard Color Block For Color Sensor but it still is not working. Any tips?
I assume by what you mean when you say “Shuffleboard isn’t displaying the colors in the boxes”, is that you have followed the code example line by line, but the color boxes that show up only show up as Green when true and Black as false. If that is the case, in order to change the color display on the Shuffleboard widget, you need to right-click the widget and select “Properties” in order to modify what colors the widget shows when it is either true or false. If this is not correct, please specify in more details what your exact issue is.
