Shuffleboard crashes on launch. Looking at the log file, it’s running into an uncaught exception. I’ve yet to find anything about this specific error online, and an hour-plus of messing around with common solutions to shuffleboard issues has been fruitless.
I’m running Windows 7 64 bit with JDK 11.0.5.
Here is the log:
Jan 11, 2020 6:44:02 PM edu.wpi.first.shuffleboard.api.util.Storage findOrCreate INFO: Creating directory C:\Users\4131\Shuffleboard\themes Jan 11, 2020 6:44:02 PM edu.wpi.first.shuffleboard.app.Shuffleboard init INFO: Build time: 2020-01-02T05:29:12.975704Z Jan 11, 2020 6:44:02 PM edu.wpi.first.shuffleboard.app.plugin.PluginLoader load INFO: Loading plugin edu.wpi.first.shuffleboard:Base:1.1.8 Jan 11, 2020 6:44:02 PM edu.wpi.first.shuffleboard.app.plugin.PluginLoader load INFO: Loaded plugin edu.wpi.first.shuffleboard:Base in 302ms Jan 11, 2020 6:44:03 PM edu.wpi.first.shuffleboard.app.Main lambda$main$0 SEVERE: Uncaught exception on thread `main`. java.lang.RuntimeException: Exception in Application init method at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:895) at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:195) at java.base/java.lang.Thread.run(Thread.java:834) Caused by: java.lang.UnsatisfiedLinkError: C:\Users\4131\.wpilib\nativecache\windows\x86-64\ntcorejni.dll.3c6943b78f09e4c7924bd7fb8258564e: Can't find dependent libraries at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method) at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2430) at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2487) at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2684) at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2617) at java.base/java.lang.Runtime.load0(Runtime.java:767) at java.base/java.lang.System.load(System.java:1834) at edu.wpi.first.wpiutil.RuntimeLoader.loadLibrary(RuntimeLoader.java:100) at edu.wpi.first.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:36) at edu.wpi.first.networktables.NetworkTableInstance.getDefault(NetworkTableInstance.java:93) at edu.wpi.first.shuffleboard.plugin.networktables.NetworkTablesPlugin.<init>(NetworkTablesPlugin.java:46) at edu.wpi.first.shuffleboard.app.Shuffleboard.init(Shuffleboard.java:82) at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:824) ... 2 more
