We recently updated one of our programming laptops to windows 10, and as such, had to reinstall everything related to FRC/WPI. Everything seemed to install correctly, except whenever we attempt to launch Shuffleboard or Smartdashboard, they crash on startup. The Driver Station, VsCode and the WpiLib extension seem to be working (eg Can build and deploy code, control the robot, ect).
We have reinstalled the VS Code extension multiple times, are using JDK 11.0.6, and have also reinstalled the NI FRC Game Tools, but we continue to get the same error.
Log file:
shuffleboard.2020-02-14-17.06.21
Feb 14, 2020 5:06:22 PM edu.wpi.first.shuffleboard.app.Shuffleboard init
INFO: Build time: 2020-01-17T04:20:13.840853Z
Feb 14, 2020 5:06:22 PM edu.wpi.first.shuffleboard.app.plugin.PluginLoader load
INFO: Loading plugin edu.wpi.first.shuffleboard:Base:1.1.8
INFO: Loaded plugin edu.wpi.first.shuffleboard:Base in 137ms
Feb 14, 2020 5:06:22 PM edu.wpi.first.shuffleboard.app.Main lambda$main$0
SEVERE: Uncaught exception on thread 'main'.
java.lang.RuntimeException: Exception in Application init method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:895)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:195)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.UnsatisfiedLinkError: C:\Users\Robot\.wpilib\nativecache\windows\x86-64\ntcorejni.dll.3a2a6785d3344c15bef2ecdbfaac0c13: Can't find dependent libraries
at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method)
at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2430)
at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2487)
at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2684)
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2617)
at java.base/java.lang.Runtime.load0(Runtime.java:765)
at java.base/java.lang.System.load(System.java:1834)
at edu.wpi.first.wpiutil.RuntimeLoader.loadLibrary(RuntimeLoader.java:100)
at edu.wpi.first.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:36)
at edu.wpi.first.networktables.NetworkTableInstance.getDefault(NetworkTableInstance.java:93)
at edu.wpi.first.shuffleboard.plugin.networktables.NetworkTablesPlugin.<init>(NetworkTablesPlugin.java:46)
at edu.wpi.first.shuffleboard.app.Shuffleboard.init(Shuffleboard.java:82)
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:824)
... 2 more
We have checked the file location it complains about in the above log stack trace, but it does in fact exist, and it is the only file in the folder. (As a side note, we are not sure “who” installed this file, the NI Tools Suite or the VsCode Wpi Extension)
At this point, we are running out of ideas, and were wondering if anyone else had experienced this problem, or had any other suggestions. We have not had this issue on other laptops, both windows 7 and 10.
