When the add
method is called on a Shuffleboard tab multiple times with the same title, it throws an error that terminates the program.
In WPILib’s documentation, it states that:
Sending simple data (numbers, strings, booleans, and arrays of these) is done by calling
add
on a tab. This method will set the value if not already present, but will not overwrite an existing value.
(See: Sending data — FIRST Robotics Competition documentation)
Thus, it should simply overwrite the data rather than throwing an error. An example of this:
package frc.robot;
import edu.wpi.first.wpilibj.shuffleboard.Shuffleboard;
import edu.wpi.first.wpilibj.shuffleboard.ShuffleboardTab;
@Override
public void robotInit() {
ShuffleboardTab tab = Shuffleboard.getTab("Example Tab");
tab.add("Example 1", 0.0);
tab.add("Example 1", 1.0); // This throws the error!
Rather than changing the value like it says in the documentation, it errors. stops the program.
The error thrown:
Error at frc.robot.Robot.robotInit(Robot.java:14): Unhandled exception: java.lang.IllegalArgumentException: Title is already in use: Example 1
at edu.wpi.first.wpilibj.shuffleboard.ContainerHelper.checkTitle(ContainerHelper.java:139)
at edu.wpi.first.wpilibj.shuffleboard.ContainerHelper.add(ContainerHelper.java:73)
at edu.wpi.first.wpilibj.shuffleboard.ShuffleboardTab.add(ShuffleboardTab.java:66)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:107)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:373)
at edu.wpi.first.wpilibj.RobotBase.lambda$startRobot$0(RobotBase.java:443)
at java.base/java.lang.Thread.run(Thread.java:833)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:388): The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
See https://wpilib.org/stacktrace for more information.
The program builds successfully, but errors when the code runs. I am currently running this in a simulator, not on a physical RoboRio.
Am I doing something wrong, or is this an error with WPILib?
