Does anyone have a simplified model of the Falcon 500 without all the fancy electronics and stuff inside of it? My computer starts to slow down quite a bit when I load in the model of a Falcon. Also, does anyone have a good way of mating falcon gears, pulleys, and couplers to the falcon shaft?
If you go into the model tree of whatever software youâre using, I think you should be able to access the center axis of whatever youâre trying to mate. Thatâs what I do for Inventor.
MKCad in Onshape has a pretty good simplified model. Also onshapeâs mate system makes it really easy to mate pinions on falcons, but ymmv.
If you zoom in a lot and select the âflatâ surface of a gears tooth, you can use a concentric mate between that and the bolt hole in the falcons shaft to mate them.
If youâre using Solidworks, it might be a good time to get practiced with Lightweight Components. Being able to turn on/off full detail is a good skill to master.
As a specific argument for this method, it enables doing basic body design (motor placement, gear mesh, etc). When thatâs all done, you can then turn âonâ the finer details (through-hole pins, connectors, etc) to do the cable routing. 99.9% of FRC robots donât do cable routing, but learning foundational skills to enable future CAD skills is a good habit to get into.
I put a somewhat simplified falcon in here⌠under electronicKOP/motors.
(sorry when the library was started motors came from the KOP).
From what I saw that,the pcb was in the model that really added to the model complexity. I would suggest that vex/ctre could use the defeature tool in Solid works to help simplify the model.
Itâs a bit janky, but I use the ID of the spline on the pinions and mate it concentric (Solidworks) to the inside hole of the output shaft. After that I can use regular coincident, distance, etc. mates to position along the shaft.
Using the top/right/front planes of the part files is a great way to mate things, and generally will help SW not slow down too much once you start having a lot of mates.
