Simple Score Calculator 2020
Let me know if anything is off
This assumes one advances to the next stage with minimum required capacity
How do I use it outside of “view only” mode?
Make a copy and save it to your local drive.
Correct me if im wrong, but i think you missed leaving the initiation line points (5/robot in auto)
Thanks for the catch, fixed
This is great! Not completely sure, but don’t you need to score 29 before you can activate rotation, then 49 before you can activate position, rather than 9 and 29? Also, I think the position control also should require the rotation control to be ‘Yes’.
@ElliotKC That is correct. The wheel can only be rotated after Stage 2 reaches capacity, so after 29 balls, and positioned after Stage 3 reaches capacity, so after 49 balls.
