Simplified Field Elements
Team 4533 created simplified field elements in Onshape: Speaker, Amp, Source & Stage.
Please use as you see fit, but verify all critical dimensions!
b094bc2c95344c0ff2f8d
This is awesome! I’m sure many teams have made similar things, but thank you for sharing!
Right now I only see the amp available:
You may need to make another version that has the rest of the elements in it.
That’s strange. My document shows all 4 field elements, finished about 11:00 am Sunday morning. I added the Note Sunday night.
Another team said they see all 4 elements. Do you still only see the Amp?
Kind of wondering if the stage will fall over w/o a 3rd leg…
Humans say upright with only two legs. Most of the time…
Maybe harder with a big booty hanging out back like that though…
That’s on the main version, which is the active working one. The one everyone has access to is version 1, which only has the amp.
You need to make a new version for everyone to get the updated ones.
Thank you Phil! I’m somewhat new to Onshape.
Can you see all 4 elements now?
LINK
Yep! I can get them now.
Thanks again for this!
On the stage, you really want more bracing on the two support legs. The robot’s weight is going to put a lot of force on those supports, and they will tend to bend inward. Here’s what the “official” elements do for this.
:thinking:
These seem to be intended for use in CAD only.
(If you’re really concerned the entire structure would tip backwards since it’s missing the other leg :laughing: )
Yes - these are intended for CAD only, to help design your robot.
Each element is only one-piece. I don’t know how you would fabricate them, unless you had a 3D printer with an 8’ tall print capability!
