Simultaneous/dependent animation in Onshape assembly?
I’m trying to set up a presentation with an Onshape assembly and I want to simultaneously animate or link two parts (to be animated together). How do I do this?
How are the two parts supposed to move? You can set up two mates with the motion relation mates (far right side).
There is gear, rack/pinion, screw, and linear. Then once you do this you can animate just one of the mates and both will move.
Take a look at this example I had for my students two years ago.
https://cad.onshape.com/documents/8cd9f3ae9f80d6e90cecec18/w/30cfeb6642d9832fcd20528f/e/7a37d4173079a2fe6b5212b9?renderMode=0&uiState=6388ea96559deb69ff76570d
This is amazingly helpful, thanks!
