After I upgrade the firmware with the latest realease and the cRIO with the latest firmware.
Does all the coding delete? I mean…Will the controller work if I wired it to the cRIO or do I need to make a code again?
You should just have to redownload your code.
I just chose the only one that was there. But I can use the tank one just to test out my jaguars?
