SmartDashboard Camera Stream Viewer - Add a Line/Grid
My team just put a camera pointing at the front of our intake.
My mentor mentioned that it would be very helpful for the drivers if they could see some sort of crosshair/line/grid to help them line up with the balls.
Is there anyway I can do that in the code?
Any kind of help is appreciated :slight_smile:
Use Shuffleboard.
The built in camera stream widget has the options to put the cross hair on.
Edit to add, I think the crosshair is set to show by default, so just adding the widget should do what you want. In case you weren’t familiar with how to do that here’s a sample that will most likely work (untested code):
Shuffleboard.getTab("DriverTab").add("Intake View", new UsbCamera("intake", 0))
            .withWidget(BuiltInWidgets.kCameraStream)
            .withPosition(0, 0)
            .withSize(3, 3);
That should put a camera stream on a tab in shuffleboard that is size 3x3 tiles, placing it on the top left of that tab.
