SmartDashboard Camera
We are having trouble getting the camera feed to work in Smart Dashboard. If we run the Driver Station in Labview we can see the camera feed, however when we add a camera object in Smart Dashboard it just says no connection.
Thanks!
Do you have the IP in smartdash set up to the cameras static IP (supposed to be static to team number, 10.xx.yy.11)?
Is there an FRC user set up on the camera?
Did you enable anonymous viewing on the camera? It is not required for LabVIEW dashboard, but is required for SmartDashboard.
That worked, thanks so much!
