The goal of my code is to be able to switch between vision processing from one camera to another camera.
I have created 2 vision threads, either one or the other is started at one time.
On the SmartDashboard, the camera shows for about a second at 1 fps and 6mbps, then turns off, and repeats. I cannot figure out the issue. Here is the code
* Sync vision variables from thread to thread.
imgLockGoal = new Object();
imgLockGear = new Object();
* Image used to be processed by a CvSink and outputted through a
* CvSource.
image = new Mat();
* Camera used to track vision targets on the boiler.
cam0 = new UsbCamera("cam0", 0);
cam0.setResolution(camWidth, camHeight);
cam0.setFPS(16);
* Camera used to track vision targets on the airship.
cam1 = new UsbCamera("cam1", 1);
cam1.setResolution(camWidth, camHeight);
cam1.setFPS(16);
* CvSink used to grab and process the image used to output to the
* CvSource
selectedVid = CameraServer.getInstance().getVideo(cam0);
* CvSource used to output the processed image onto the SmartDashboard
* (CameraServer Stream Viewer).
outputStream = CameraServer.getInstance().putVideo("Tracking", camWidth, camHeight);
* Vision Thread uses the high goal contour filtering to find the best
* targets and help lead the robot to the target destination.
visionThreadHighGoal = new VisionThread(cam0, new VisionClass(), pipeline -> {
selectedVid.grabFrame(image);
if (pipeline.filterContoursOutput().size() >= 2) {
//isTargetFound = true;
Rect r = Imgproc.boundingRect(pipeline.filterContoursOutput().get(0));
Rect r1 = Imgproc.boundingRect(pipeline.filterContoursOutput().get(1));
Imgproc.rectangle(image, new Point(r.x, r.y), new Point(r.x + r.width, r.y + r.height),
new Scalar(0, 0, 255), 2);
Imgproc.rectangle(image, new Point(r1.x, r1.y), new Point(r1.x + r1.width, r1.y + r1.height),
outputStream.putFrame(image);
synchronized (imgLockGoal) {
centerX = (r.x + (r1.x + r1.width)) / 2;
width = (r.x + r1.x) / 2;
} else {
//isTargetFound = false;
}); visionThreadHighGoal.start();
// TODO: change filters to specify for gears
* Vision Thread uses the gear contour filtering to find the best
visionThreadGear = new VisionThread(cam1, new VisionClass(), pipeline -> {
synchronized (imgLockGear) {
// TODO:
} else {
Thanks!
