Hi, I am having an error whenever I run certain code on the roborio.
When i commented out all of the code in method driveForward() except the variable declarations, the console doesn’t output any errors, but when I uncomment and include leftEncoder.reset() and rightEncoder.reset(), I get an error that disables my robot. Any help is appreciated.
This is the code I am running:
package org.usfirst.frc.team5242.robot;
import edu.wpi.first.wpilibj.AnalogInput;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.interfaces.Accelerometer;
This is a sample program to demonstrate the use of a soft potentiometer and
proportional control to reach and maintain position setpoints on an elevator
mechanism. A joystick button is used to switch elevator setpoints.
WARNING: While it may look like a good choice to use for your code if you’re
inexperienced, don’t. Unless you know what you are doing, complex code will
be much more difficult under this system. Use IterativeRobot or Command-Based
instead if you’re new.
public class Robot extends SampleRobot {
//Drive Objects
BuiltInAccelerometer accel;
RobotDrive drive;
Joystick stick;
Encoder leftEncoder;
Encoder rightEncoder;
Accelerometer accelerometer;final int kPotChannel = 1; // analog input pin
final int kMotorChannel = 7; // PWM channel
final int kJoystickChannel = 0; // usb number in DriverStation
final int kButtonNumber = 4; // joystick buttonfinal double kSetPoints] = { 1.0, 2.6, 4.3 }; // bottom, middle, and top
// elevator setpointsfinal double kP = 1.0; // proportional speed constant
double motorSpeed;
double currentPosition; // sensor voltage reading corresponding to current
// elevator position// make objects for the potentiometer, elevator motor controller, and
// joystick
AnalogInput potentiometer = new AnalogInput(kPotChannel);
Victor elevatorMotor = new Victor(kMotorChannel);
Joystick joystick = new Joystick(kJoystickChannel);public Robot() {
}public void driveForward2(float distance, float speed)
public void driveForward(float distance, float speed)
int pulsesPerRev = 1024;
double inchesPerRev = 6.0 * 3.141;
double currentSpeed;
double currentDistance;
double acceleration;
double deceleration;
double driveDelay;currentSpeed = 0.0; currentDistance = 0.0; acceleration = 0.01; deceleration = 0.02; driveDelay = 0.01; //rightEncoder.reset(); //leftEncoder.reset(); rightEncoder.setDistancePerPulse(inchesPerRev / pulsesPerRev); /*while(currentDistance < distance) { SmartDashboard.putNumber("Distance", currentDistance); if (currentSpeed < speed) { currentSpeed = currentSpeed + acceleration; } //drive.tankDrive(currentSpeed, currentSpeed); drive.tankDrive(0, 0); Timer.delay(driveDelay); currentDistance = (rightEncoder.getDistance() + leftEncoder.getDistance()) / 2; } while (currentSpeed > 0) { currentSpeed = currentSpeed - deceleration; if (currentSpeed < 0.0) currentSpeed = 0.0; drive.tankDrive(currentSpeed, currentSpeed); Timer.delay(driveDelay); } */}
- Runs during autonomous.
@Override
public void autonomous() {
//drive.setSafetyEnabled(false);
SmartDashboard.putNumber(“start go”, 1);
driveForward((float) 24.0,(float) 5.0);
SmartDashboard.putNumber(“stop”, 5);
//drive.setSafetyEnabled(true);
Moves elevator to a selectable setpoint that can be changed by pressing a
button on the joystick. Proportional control is used to reach and
maintain the desired setpoint by obtaining values from the potentiometer
and comparing them to the setpoint value.
@Override
public void operatorControl() {
boolean buttonState;
boolean prevButtonState = false;int index = 0; // setpoint array index
double currentSetpoint; // holds desired setpoint
currentSetpoint = kSetPoints[0]; // set to first setpointwhile (isOperatorControl() && isEnabled()) {
buttonState = joystick.getRawButton(kButtonNumber); // check if
// button is
// pressed// if button has been pressed and released once if (buttonState && !prevButtonState) { index = (index + 1) % kSetPoints.length; // increment set point, // reset if at end // of // array currentSetpoint = kSetPoints[index]; // set setpoint } prevButtonState = buttonState; // record previous button state currentPosition = potentiometer.getAverageVoltage(); // get position // value motorSpeed = (currentPosition - currentSetpoint) * kP; // convert // position // error // to // speed elevatorMotor.set(motorSpeed); // drive elevator motor}
- Runs during test mode
@Override
public void test() {
