Smartdashboard problem
The smartdashboard is not displaying values when connected to the roborio. it is receiving the ip address properly and it has not lost our team number. The code is loaded properly into the roborio. Any suggestions would be much appreciated.
Some questions:
  1. Are you able to run your robot?
  2. Is your computer on an auto ip configuration?
  3. Did you properly re-image your router?
If question number 1 is no, the answers to 2 and 3 might also be part of your problem.
We are able to run our robot, we are on an auto ip configuration and we were able to re-image the router properly
Is the connection indicator showing a connection? http://wpilib.screenstepslive.com/s/4485/m/26401/l/255407-getting-started-with-the-smartdashboard
Are you using the 2015 smart dashboard?
