SMC versus Bimba
Are there any advantages to using Bimba over SMC or vice versa?
Having only Bimba and Parker cylinders to compare, I’ve never noticed a difference. One advantage: you can get 2 free cylinders from Bimba.
FRC 4607 CIS has used a couple of different cylinders - and Bimba has never let us down.
Both SMC & Bimba make quality products. Bimba is big supporter of First.
Ditto for 3946 Tiger Robotics.
SMC parts used to be illegal (for reasons that ranged from uncertain to bad). As a result, other teams tend to be a lot more familiar with the Bimba equivalents, and may be more likely to carry them as spares. But many cylinders are standard and interchangeable.
The product lines have substantial overlap, but you’ll find that SMC in particular makes a lot of very heavy industrial cylinders that Bimba doesn’t. But you probably don’t want those anyway.
Basically, read the manuals thoroughly to familiarize yourself with what’s available, and make your selection based on features, cost and availability rather than reputation. Both will likely be fine.
http://www.bimba.com/Products-and-Cad/Actuators/
http://www.smcusa.com/top-navigation/products/actuators-air-cylinders.aspx
