Snapping 775 Pro Shaft
So my team somehow was able to snap the shaft off while running a 775 Pro. We had an AM 12t Pinion on it when it snapped, connected to our drivetrain. For those teams that ran 775 drivetrains last year (2767, 2451, 3357, etc.), did you ever discover any failures similar to this?
We at first believed it was due to a lot of sudden forward and then reversing while driving but later we remembered our gearboxes became loose at one point and we are wondering if the sag of the motors put too much stress on the pinion, later causing it to fail. The pinion has an unusual wear pattern on it (flat teeth in a few spots but we have an enclosed gesrbox so could be due to getting wedged somewhere after failing).
And by the way, the motor still runs.:rolleyes:
We blew through a Versa Planetary last night… :confused:
Can you post a close up picture of the end of the shaft while it is not spinning? From your description of the sagging motors, my guess is bending fatigue.
Was it running when that picture was taken? Most of the image is very clear, but the broken shaft surface looks blurry. A better look at that surface might help identify the failure mode.
When you said the gearboxes became loose, did you mean the motor screws?
Do you have a picture of your gearbox or at least how the gearing is laid out?
I’ll take a picture later of it not spinning. I took some without it spinning but they were blurry so I screenshotted a video.
With our current setup, the screws holding the gearbox together holds the motors in, so technically the motor screws became loose.
Were these motors in a custom gearbox? Were the pinions double-loaded?
-Nick
This is how the gearbox is currently setup. We are using AM DeCIMates connected to modified WCP SS (little smaller than normal configuration). If I can remember off the top of my head, we had a 26.775:1 reduction (total final reduction to the wheel, 6" wheel).
Since the picture was taken, plastic covers were added to keep grease in and dirt out.
It looks like either ductile torsional failure:
Or bending+rotating failure:
Possible that you got a motor without a heat-treated shaft, but perhaps more likely that the bending load from having the motor ‘sag’ induced a fracture that grew as the motor continued in use.
Edit: looks just like the fracture pattern for ‘severe stress riser’ in rotating+bending fatigue failure. Perhaps something to do with how the pinon was pressed on or made.
I’ve had a RS550 fail like this when the motor mount to the GB got loose.
In the first picture; the lower mounting screw location looked damaged, and turned to an angle. It appears this motor bolt could have been cross-threaded off center.
There is also no indication of any red or blue traces on the threads, indicating no Loctite was used.
I would venture to guess it was the side loading from the gearbox coming loose. You could also have picked something up between the spur and pinion gear. A screw, rivet, washer, etc. The motor just doesn’t have the torque to snap a shaft like that. If you started and stopped super quick, the armature would reverse direction before you could snap a shaft. The only other thought that comes to mind is the pressing of the pinion onto the shaft might have damaged the shaft which then broke.
2451 has never had a 775Pro shaft failure.
The motors we installed at the beginning of last season are still on our comp bot.
Yeah in our off season 775pro drivetrain and in the history of abusing 775pros we’ve never seen a failure like that.
Here is a picture of the shaft snapped while not moving. If it’s blurry, I’ll try to re-upload. CD didn’t like the original pictures size.
All of the flaked-off plating around the motor mounting holes makes me think that motor was moving around a lot.
Definitely a bending while rotating fatigue fracture, likely a result of poor mounting. Looks like it probably broke at the root of the spur gear, judging from the indication of ‘high stress concentrations’ in the fracture pattern.
2767 never experienced 775pro shaft failures on either drive train or implement applications. However, our wheel size and gear ratios are far lower than yours.
For what its worth, we have done a lot of off season torture testing with heavy flywheel RD Slams and didn’t see any shaft failures.
My take on that picture is fatigue failure following damage from the eccentric loading–based on the stated history and both on the type of break and the worn plating as noted previously.
Okay thank you! We didn’t even think about adding Loctite when assembling, we ended up adding it later when we realized they were loose, but st that point, I believe the damage was already done to this motor.
We never had the issues you described. We used 12 of them on our robot last year and are using 8 this year. The only issues we’ve ever had with them are with the CIM-ile gears and overheating. Using the 12T 32DP gears meshed with the 80T 32DP gears from West Coast Products seems to work well.
