Hey there. Is it just me, or does the www.soap108.com website not work anymore? When I search for a team, the only thing that comes up is a page that says “Error Occurred While Processing Request.” Has there been any mention here of why that happens?
Works 4 Me
I can load the page, but when i search for team 47 up in the top-left, i get ‘The page cannot be found’
*Originally posted by Brandon Martus *
**I can load the page, but when i search for team 47 up in the top-left, i get ‘The page cannot be found’ **
I get this when i search
Error Diagnostic Information
ODBC Error Code = IM002 (Data source not found and no default driver specified)
[Microsoft][ODBC Driver Manager] Data source ‘TEAM108SQL’ not found and no default driver specified
Hint: In order to use ODBC data sources with Cold Fusion you must create the data source using the Data Sources page of the Cold Fusion Administrator. In addition, if you are running under Windows NT you must make sure that the Data Source is created as a System DSN in order for it to be available to ColdFusion.
The error occurred while processing an element with a general identifier of (CFQUERY), occupying document position (36:1) to (36:60).
Date/Time: 10/18/02 16:18:42
Browser: Mozilla/4.0 (compatible; MSIE 5.15; Mac_PowerPC)
Remote Address: 66.31.80.243
HTTP Referrer: http://www.soap108.com/2002/scouting/index.cfm
We’ve contacted our hosting company and hope to have the ODBC/DSN issue fixed soon.
Thanks,
KA-108
