wiring of the solenoid valves is proper, i do not know if the breakout is using 24 volt power as opposed to 12, however, when defining the Solenoids as such:
Sol1 = new Solenoid(1);
should the word Solenoid(after new) be recognized and highlighted or does it remain unlighted. as well as, why would windriver not recognize the joystick command for GetRawButton. It recognizes everything but GetRawButton, therefore, it does not work i must use GetTrigger or GetTop.
Ex. if(rightStick.GetRawButton(4))
{Sol1 -> Set(true);}
