Solenoid Connectors
Does anyone know where I can buy the wire connectors for this solenoid? I have been looking and it seems that the only way to get them is to buy the whole solenoid again.
I wasn’t able to find a good picture or description of that connector online.
I have used 1 pin dupont header connectors (same as PWM connectors) to interface with our SMC solenoids. I slip them onto the pin and hot glue them in place. If your solenoid has similar male pins this should work for you in a pinch.
Thanks for the response.
