hi,
our team has almost a day left before we put the robot in a box and ship it out so please answer quick.
we have programmed and wired correctly the 2 double solenoids that we are using, the lights changed from side to side (like their suppose to), and the the pneumatic pistons have pressure in them. But when we push the buttons to go down and up the pistons do not change.
What voltage do you have wired into the Solenoid Breakout - 12v or 24v?
Is the power status light on the Solenoid Breakout bright green?
Does the Solenoid Breakout have 2-pin ports or 3-pin ports?
*]Are the red wires connected from the solenoid to the outside pin on the Solenoid Breakout, and the black wire connected to the inside pin of the connection?
Someone else just asked that earlier today–use the open slots in the 24V port the cRIO connects to. I believe they’re C and NC, can’t quite remember which wire goes to which.
