Hi CD,
This is my first year programming, and 4618’s first year using pneumatics. I’ve programmed according to the WPIlib screensteps and I keep getting an error every time I save and build the program.
Here’s what I’ve done(copied from sections of the program):
DoubleSolenoid *m_leftShifter;
m_leftShifter = new DoubleSolenoid(LEFT_DRIVE_LOW,LEFT_DRIVE_HIGH);
m_leftShifter.set(DoubleSolenoid.Value.kForward);
If someone could tell me what I’m doing wrong or how to fix this it would really be appreciated. If it helps, programming it as a Solenoid instead of DoubleSolenoid and using m_leftShifter.set(true); did not get rid of the problem.
EDIT: I could set a motor value successfully, just not the solenoids.
Thanks
