Solenoid toggle
I was wondering how to create a toggle function in Lab View for activating and deactivating pnuematics but as a repeatable function
i.e. when button one is pressed set solenoid to open; when button one is pressed (again) set solenoid to closed; and for that function to be a user controlled repeatable function.
second question:
how do I wire button 1 to the solenoid set function and have a boolean true/false indicator/variable set wired into the set function as well. or do I have the wiring completely wrong
detailed instructions are preferable but not required
Thank you
-Newman
There’s an example here about halfway down the page.
The toggle is just one example, there are many other ways to do the same thing.
