solenoid valves?
Does anyone know how to wire and use the solenoid valves from the 2006 KOP?
Here is the website with the Festo instructions. 2005 and 2006 Festos are the same.
http://www.festo.com/INetDomino/us/en/44e19dbfe14c5bf6c1256c8b004fc634.htm
Pete
The Rexroth-Bosch celenoids are similar to the FESTOs in wiring but instead of quick connects for the tubing you put a nut on the tube and then screw the nut onto the fitting on the celenoid itself.
GO REXROTH-BOSCH!!!
