Solidworks Weights
Is there a way I can tell solidworks that a part weighs a certain amount without having to put in a density? For fast CAD’ing, I know how much components weigh because I can weight them; but finding their volume is another matter and it’s faster to simply weigh each piece and put it in a spreadsheet and create a simple representation of the part without all the nooks and crannies.
However, since I want to be able to simply go to our final robot drawing and then “mass properties” to get the weight, a spreadsheet will not suffice. I’d also like to put the weight on the bill of materials.
Any ideas?
Under Mass Properties, you ought to find a check box that reads “Assigned Mass Properties”. Choosing this will make the mass information user definable and you ought to be able to set it yourself. You can see that I use it frequently for KoP and COTS items.
http://img134.imageshack.us/img134/2558/masspropertiesvk2.jpg](http://imageshack.us)
Yes in SolidWorks you can assign a custom mass/weight to a part or assembly and then link that information to the drawing through Custom Properties. You are going about setting a custom mass the correct way but now you need some additional steps.
For a part of assembly, select tools, mass properties. Enter the value for the mass.
In the ConfigurationManager, right-click Default. Click Custom Properties.
Select Weight for Property Name. Select from the drop downlist “Mass” for Value. You need to use the SW-Mass
Now create your drawing, use the predefined BOM template that contains Mass. You mass from the model will be displayed.
There is a movie of the solution at
Good luck. Marie
