(Solved) Cannot get wireless connection to the RoboRio functioning
Our roborio is not connecting wirelessly. We have been able to connect it via USB, but the yellow light on the radio is not coming on. When we connected it to the other radio that we have (this is another team’s spare radio that was previously connected to another roborio) the yellow light comes on, but won’t connect to our computer. We imaged our roborio to the 2019 update suite, and the current firmware.
Have you updated your radio (router) with the 2019 updates? If not that might be the reason you can only connect wired.
We only updated the firmware and did the imaging, and we did this with our radio, not the one we borrowed.
I would try to reconfigure your radio with the 2019 software, and also make sure that your radio is connected to your roborio via ethernet. If not, there is no possible way you will be able to connect wirelessly. Heres the link to the 2019 config utility. https://wpilib.screenstepslive.com/s/currentCS/m/getting_started/l/144986-programming-your-radio
We will reconfigure it now, and I’ll let you know how it goes.
We have fixed the problem. We didn’t properly configure the radio but now that we did it is working fine. Thank you so much!
