Here are some questions my team has come up with so far.
What is the max height a robot can reach in the opponent’s home stretch? (in the manual it says 6ft but that contradicts the video shown on the kick-off)
2)Is the homestretch only considered the 1/4 section or the entire half their section is? I look at the drawing it it seemed it was only to the finish line however some member believed it was the entire half.
Can you turn your robot around after the overpass and lift a ball up? ( Lets say i pass the opponents overpass, can I then turn 180degress and place a ball on top? )
Unless I misinterpreted the Definition of Crossing in Section 7: The Game, I meant any
CROSSING: The act of a TRCKBALL or ROBOT passing through the plane defined by a line (i.e. LANE MARKER or FINISH LINE) when it is projected vertically upwards. A TRACKBALL or ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counterclockwise direction, have completely passed through the plane.
You did not misinterpret the definition. However, I quote another part of Section 7, namely 7.3.4.2:
<G22> Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
(emphasis mine)
