I am trying to get Spark Max CAN to work on our robot. I’ve ran each motor independently with a button, but when I try using the differentiable drive arcade command (it takes in speed and rotation) but it doesn’t work. I’ve called a speed controller group but it still won’t work. Here’s my setup rn 15817919835886858953872586264132|666x500
Are you getting proper inputs from your joystick? I think we need a bit more information about the code and electronic setup you used
We fixed the problem (CAN wasn’t wired correctly) but by any chance would you happen to know the button to reset the joysticks I think it’s F2 but I’m not entirely sure
