vuure
We defined intake as
PWMSparkMax intake = new PWMSparkMax(0);
and powered it with this code:
if (controller.getXButtonPressed()){
intake.set(0.5);
System.out.println("Button Pressed X");}
if (controller.getXButtonReleased()){
intake.set(0);
but this code only runs motor for like 20 miliseconds and powers it again when we pressed X again.
Oblarg
You’re only running the motor on the single iteration when the button switches from false
to true
Consider using the command-based framework, which will help with scheduling tasks and remove the need to use explicit if statements in the main loop.
vuure
3
I dont have any idea about command-based, yet i dont think i can learn it till regional. We have same part in our code which works perfectly:
if (controller.getYButtonPressed()){
shooter1.set(-1);
shooter2.set(1);
System.out.println("Button Pressed Y");}
if (controller.getYButtonReleased()){
shooter1.set(0);
shooter2.set(0);
shooter1 and shooter2 defined like:
VictorSP shooter1 = new VictorSP(1);
VictorSP shooter2 = new VictorSP(2);
Maybe try using getXButton() instead of getXButtonPressed()? This should return True as long as the button is held down.
vuure
5
Alright, we handled it (it turns out we didn’t plug NEO encoder cable).
