I am a complete neophyte when it comes to using anything more than set commands for motors (that’s what CSA’s are for!). At the moment, I am trying to figure out PID on a shooter using a pair of Spark Max’s w/ attached NEOs, direct to shaft, which is shooting power cells great using set commands, but is affected by battery voltage. We want to use PID to set an RPM so that it doesn’t matter what the voltage is, it will just get there.
If I run the motors up using just set commands, they will happily spin along at 5900 rpm when given a set(1). If I attempt the same thing using PID, the REV Spark Max Velocity Control example in particular with very little alteration other than there are 2 motors involved, the motors will go up to ~1820 rpm and stay there when given the same speed command of 1 and max rpm of 5700.
This is completely test code on my personal machine, so no Github, but here is the short code for just testing running the shooter, both with discrete set commands as well as PID. The goal is quite simple. If a shoulder button is pressed, either the left or right motor will turn individually to whatever shooterspeed is discretely set to (a slider on the dashboard that goes from 0 to 1 since we don’t want to run backwards) to visually verify that both motors are going to turn the same direction and not fight each other. If Button 3 is pressed, both motors spin at the same discrete shooterspeed set command. If Button 4 is pressed, it should take that same shooterspeed entry, multiply it by the max rpm variable (defaulted to 5700 and hasn’t been changed during testing), and feed that into the PID command as a target velocity.
Currently using the discrete set commands results in the expected velocity from 0 to 5700/5900 rpm depending on running only 1 or both motors. Using PID, with the numbers given in the REV example, is producing both motors spinning at 1820 rpm. Trying to slow the shooter wheel down does indeed cause the Spark Max’s to feed “moar power” to speed it up, so PID is working somewhat, just not to the 5700 that I believe it ‘should’ be doing when given a shooterspeed of 1.
My understanding of PID, at least what I can understand when reading about it, is that the P-I-D variables affect how the setpoint is achieved, but that it will achieve it eventually. It may be jerky or slow to get there, but it will. Is that not correct? Keep in mind that the below PID values are directly from the REV Velocity Closed-Loop example, with no tuning yet since I can’t get it to get to full speed yet.
Is there something glaring that I’m missing here?
Thanks for looking!
package frc.robot;
import com.revrobotics.CANEncoder;
import com.revrobotics.CANPIDController;
import com.revrobotics.ControlType;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import edu.wpi.first.wpilibj.PowerDistributionPanel;
/* Joysticks */
Joystick gamepad = new Joystick(0);
/* Power Distribution Panel */
PowerDistributionPanel pdp = new PowerDistributionPanel();// add pdp functions
/* Variables */
int shooterrightid = 12;
int shooterleftid = 13;
double shooterspeed = 0;
public double kP, kI, kD, kIz, kFF, kMaxOutput, kMinOutput, maxRPM;
/* Shooter Motors */
CANSparkMax shooterright = new CANSparkMax(shooterrightid, MotorType.kBrushless);
CANSparkMax shooterleft = new CANSparkMax(shooterleftid, MotorType.kBrushless);
/* Shooter Encoders */
CANEncoder shooterrightencoder = new CANEncoder(shooterright);
CANEncoder shooterleftencoder = new CANEncoder(shooterleft);
/* Shooter PID */
CANPIDController shooterrightPID = new CANPIDController(shooterright);
CANPIDController shooterleftPID = new CANPIDController(shooterleft);
@Override
public void robotInit() {
/* Set up shooter for 2 motors, one on each side, individually no followers currently */
shooterright.restoreFactoryDefaults();
shooterleft.restoreFactoryDefaults();
shooterright.setInverted(false);
shooterleft.setInverted(true);
// PID coefficients
kP = 6e-5;
kI = 0;
kD = 0;
kIz = 0;
kFF = 0.000015;
kMaxOutput = 1;
kMinOutput = 0;
maxRPM = 5700;
// set PID coefficients
shooterrightPID.setP(kP);
shooterrightPID.setI(kI);
shooterrightPID.setD(kD);
shooterrightPID.setIZone(kIz);
shooterrightPID.setFF(kFF);
shooterrightPID.setOutputRange(kMinOutput, kMaxOutput);
shooterleftPID.setP(kP);
shooterleftPID.setI(kI);
shooterleftPID.setD(kD);
shooterleftPID.setIZone(kIz);
shooterleftPID.setFF(kFF);
shooterleftPID.setOutputRange(kMinOutput, kMaxOutput);
// display PID coefficients on SmartDashboard
SmartDashboard.putNumber("P Gain", kP);
SmartDashboard.putNumber("I Gain", kI);
SmartDashboard.putNumber("D Gain", kD);
SmartDashboard.putNumber("I Zone", kIz);
SmartDashboard.putNumber("Feed Forward", kFF);
SmartDashboard.putNumber("Max Output", kMaxOutput);
SmartDashboard.putNumber("Min Output", kMinOutput);
SmartDashboard.putNumber("Shooter Speed", 0);
@Override
public void robotPeriodic() {
SmartDashboard.putNumber("Total", pdp.getCurrent(0) + pdp.getCurrent(1) + pdp.getCurrent(2) + pdp.getCurrent(3) + pdp.getCurrent(4) + pdp.getCurrent(5) + pdp.getCurrent(6) + pdp.getCurrent(7) + pdp.getCurrent(8) + pdp.getCurrent(9) + pdp.getCurrent(10) + pdp.getCurrent(11) + pdp.getCurrent(12) + pdp.getCurrent(13) + pdp.getCurrent(14) + pdp.getCurrent(15));
SmartDashboard.putNumber("Right RPM", shooterrightencoder.getVelocity());
SmartDashboard.putNumber("Left RPM", shooterrightencoder.getVelocity());
shooterspeed = SmartDashboard.getNumber("Shooter Speed", 0);
// read PID coefficients from SmartDashboard
double p = SmartDashboard.getNumber("P Gain", 0);
double i = SmartDashboard.getNumber("I Gain", 0);
double d = SmartDashboard.getNumber("D Gain", 0);
double iz = SmartDashboard.getNumber("I Zone", 0);
double ff = SmartDashboard.getNumber("Feed Forward", 0);
double max = SmartDashboard.getNumber("Max Output", 0);
double min = SmartDashboard.getNumber("Min Output", 0);
// if PID coefficients on SmartDashboard have changed, write new values to controller
if((p != kP)) { shooterrightPID.setP(p); shooterleftPID.setP(p); kP = p; }
if((i != kI)) { shooterrightPID.setI(i); shooterleftPID.setI(i); kI = i; }
if((d != kD)) { shooterrightPID.setD(d); shooterleftPID.setD(d); kD = d; }
if((iz != kIz)) { shooterrightPID.setIZone(iz); shooterleftPID.setIZone(iz); kIz = iz; }
if((ff != kFF)) { shooterrightPID.setFF(ff); shooterleftPID.setFF(ff); kFF = ff; }
if((max != kMaxOutput) || (min != kMinOutput)) {
shooterrightPID.setOutputRange(min, max);
shooterleftPID.setOutputRange(min, max);
kMinOutput = min; kMaxOutput = max;
@Override
@Override
@Override
public void teleopInit() {
@Override
if (gamepad.getRawButton(6)) {
shooterright.set(shooterspeed);
else if (gamepad.getRawButton(5)) {
shooterleft.set(shooterspeed);
else if (gamepad.getRawButton(3)) {
else if (gamepad.getRawButton(4)) {
double setPoint = shooterspeed*maxRPM;
shooterrightPID.setReference(setPoint, ControlType.kVelocity);
shooterleftPID.setReference(setPoint, ControlType.kVelocity);
SmartDashboard.putNumber("SetPoint", setPoint);
else {
shooterright.set(0);
shooterleft.set(0);
@Override
public void disabledInit() {
