Spark max white/green flashing (but no limit switch plugged in)
Hey does anyone know why a spark max would flash green/white (which is forward limit) when there is no limit switch plugged in? Motor won’t move forward at all. There was a limit switch on it that worked before but it’s been completely removed now.
Update:
If we disable the limit switches then it works but we’d like to run the limit switches so it’s like something fried inside.
Have you attempted to ‘restore factory default’ in the REV Hardware Client? See if that resets it?
What type of limit switch was it? If it was normally closed, then removing it would leave it “open” and trigger the limit.
Factory default is normally open.
