Spark maxs lying about recieving a can signal
Our spark maxs are not receiving a can signal, the signal light is flashing blue and when I checked the on rev hardware client the can bus wasn’t broken. the signal was being lost intermittently. Why could this be happening?
its also worth noting that the signal was being lost on a minute timescale - really bizarre.
this could be because the spark max has the same can ID as another Sparkmax. If it isn’t that, see if the can wires are under strain or around a tight corner. if it is it can temporally disconnect it when the robot moves. if none of these are the case, see if your sparks are getting enough power.
