Spark Motor Controller Class in Java
Hi,
We are a new team to FRC and we were wondering if there was a Spark motor controller class for defining new Spark objects similar to the VictorSP or Talon motors.
Thanks
Is this it?
/* Copyright (c) FIRST 2008-2017. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj;
import edu.wpi.first.wpilibj.hal.FRCNetComm.tResourceType;
import edu.wpi.first.wpilibj.hal.HAL;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
 * REV Robotics SPARK Speed Controller.
public class Spark extends PWMSpeedController {
   * Common initialization code called by all constructors.
   * <p>Note that the SPARK uses the following bounds for PWM values. These values should work
   * reasonably well for most controllers, but if users experience issues such as asymmetric
   * behavior around the deadband or inability to saturate the controller in either direction,
   * calibration is recommended. The calibration procedure can be found in the Spark User Manual
   * available from REV Robotics.
   * <p>- 2.003ms = full "forward" - 1.55ms = the "high end" of the deadband range - 1.50ms =
   * center of the deadband range (off) - 1.46ms = the "low end" of the deadband range - .999ms =
   * full "reverse"
  protected void initSpark() {
    setBounds(2.003, 1.55, 1.50, 1.46, .999);
    setPeriodMultiplier(PeriodMultiplier.k1X);
    setSpeed(0.0);
    setZeroLatch();
    LiveWindow.addActuator("Spark", getChannel(), this);
    HAL.report(tResourceType.kResourceType_RevSPARK, getChannel());
   * Constructor.
   * @param channel The PWM channel that the SPARK is attached to. 0-9 are on-board, 10-19 are on
   *                the MXP port
  public Spark(final int channel) {
    super(channel);
    initSpark();
So the issue is that when I create a new Spark object: Spark topMotor = new Spark(1); - it compiles and uploads to the RoboRIO, however in the Driver Station it says that the robot code is not found.
I reverted to an older program without instantiating the Spark controllers and it says that the Robot Code is found and works.
Thanks
Any chance you’re already creating another PWM motor controller (Spark, Victor,Talon, etc.) object on port 1? That will crash your code and result in the symptom you described.
It should also print the error that is occurring into the Driver Station messages window (on the right side of the DS).
