SPC Battery Concern
Problems with SPC Batteries? Check this out.
Test 1
Test 2
Umm, check what out?
Had to add a link.
Hi @stevecolasanti
Thanks for running those tests and posting the videos
Three things:
  1. Did you mean to say “we’re pulling 55 amps” ?
  2. What make & model battery tester is that ?
  3. The test you ran is a high amp, low duration test. Some batteries will pass such a test, yet fail a low amp, long duration test. The latter test method sometimes detects bad cells that the former does not.
