Spectrum 3847 - Build Blog 2020
Once we decided we would shoot opposite the direction of our intake, we no longer needed to shoot over our climber. This allowed our climber to be at the full 45" height at the start of the match, so we needed far less extension and thus the drawer slides were no longer needed. A single stage, chain powered lift, is far simpler for us to build and maintain.
Very cool idea for the climb system! Have you tested this prototype/idea? There are many steps in order to climb with another robot
  • Catch the iron bar
  • Lift yourself around 70 cm ~26 inch
  • Wait for another robot to drive into the forks which might be hard since the visibility is meh from the driver station
  • Lift yourself some more
This could be around 20 - 30 seconds. Did you try to time it?
Im glad that youre using Chameleon Vision (because Im one of the developers). Can you publish your experience with Chameleon Vision in this CD thread so other teams will consider using it. As its new for this year, not a lot of teams have used it or even heard of it.
Anyway, Thanks for sharing your team progress and for taking your time to create this detailed CD thread and answering everybody’s questions! :smiley:
No we have not tested it, it should be on a similar time scale to 2018 buddy climbs, likely 20-30 secs.
We can once we have more testing.
What is the range of motion of your elevator? What is the height when its collapsed versus when its fully extended?
Seeing is as it’s not designed yet it’s hard to say, but our design goals are for our latches to start somewhere from 28"-30" off the ground and be able to latch on to the pole at 63"+ some wiggle room.
Day 12: New intake/indexer Plan
Block Robot Update
The new intake plan, allows for balls to rapidly be brought into the robot with a wide intake, and set quickly into the tower using a powered V similar to prototype videos from FRC#6135, FRC#4481 and FRC#95 . We plan to prototype some variations of this idea by adding a central channel for balls to rolls straight down and possibly a powered belt to move balls towards the tower belting as well. We will test various options for the side conveyors/wheels and also speeds and direction changes.
The tray on top of the intake is designed so this robot would be able to load from the human player station with the intake down. That should allow us to intake balls on the ground and then quickly get any remaining needed balls from the loading bay when drive in.
When retracted the intake acts as a cage around any balls remaining in the funnel to not allow them to bounce out of the robot as we drive over the boundaries.
We have prototypes of these systems under constructed and will post video and photos when they are operational.
Spectrum
Terrific update. Thanks for the insight.
How is that shooter wheel constructed? Looks like 6" pvc on some type of hub.
Currently we are stacking multiple 6" drive train wheels as a shooter. It works, but is not the best approach for weight and inertia.
David
Currently testing with a very wide VEXpro 6" traction whee (lots of tires stacked together on a printed slicel. We will also test with 6" colson wheels.
Every time I look at your prototypoe shooter I admire how flexible it is to test! Ours definitely takes much more time to rework different configurations.
Flexibility is actually causing some of our issues, our hood isn’t rigid enough for proper testing, we are continuing to improve it.
Ah thank you for the info. I was feeling bad it takes us an hour to reassemble any changes.
Not to hijack Allen’s thread, but if you are looking for some suggestions we had good luck with rapid modification using a shooter prototype modeled after one in the 254’s 2016 Notebook.
Everything is fixed except the actual back cowl parts, one of which is highlighted in blue above. You can change the compression, backing, and release angle by just changing these out for different ones with a couple of bolts. This was designed around laser cut 1/2" plywood (because that’s what we have), YMMV.
It’s still in evolution, but something like 2 geared up NEOs running closed loop control was pretty happy. Not shown in CAD was we pretty quickly realized looking at the logs that we needed more inertia so the actual set-up has a pile of gears also on the shaft:
Hijack away, Rachel, especially if it’s good ideas. Thanks for the ideas, I’ll pass along to the kids that have been doing our hood and see if we can incorporate some of the ideas.
This is what we’re building, basically. This is plagarism :stuck_out_tongue:
The similarity we’re getting to a lot of the #openalliance folks is uncanny. We haven’t even been paying too much mind to y’all and we’re getting the same basic robot shape…
Either great minds think alike or we’re all sheeple-ing along.
Thank you for the information. We aren’t a strong cad group but our test setup is getting closer to that naturally though starting to have alot of holes drilled by hand that we’ll probably remake them.
A group lesson learned in foresight on the prototype adjustment.
I think it’s a relatively common path
Always excited to see a build blog especially from 3847! Looking good so far
Shooter
The shooter prototype was updated with a more rigid hood and basic velocity control on the NEO motors. It’s shooting with 2 NEOs powering a 6" wheel 1:1 at 5000 RPM and a 4in accelerator wheel powered by 1 NEO 1:1 at 5000RPM. We plan to update the shooter to gear the main flywheel up so the NEOs have more power head room to maintain an RPM of around 5000. We also may test powering the accelerator wheel off the same two NEOs that are powering the main fly wheel.
Intake
Our newest intake prototype is meeting all our expectations for an intake. The balls are rapidly moved up into our robot and our new indexer should be able to sort out the 3 wide balls pretty easily in the unlikely case we are intake 3 balls all sitting next to each other.
Indexer
The indexer prototype based on FRC#6135 is working flawlessly.
Video of it working without intake
More Pictures and Video of all the systems are available in our photo gallery.
Spectrum Dead Axle Rollers
The roller setup we have been using in our prototypes are based on a system we developed for our 2019 Cargo intake. We plan to use it again for our Power Cell intake.
The system has 6 parts
  1. 7/8" Aluminum Tubing
  2. 1.125" ID x 1.25" OD Polycarbonate Tubing
  3. McMaster Tube Connecting Nuts for 7/8" Tube
  4. 7/8" ID x 1.125" OD Needle Bearings
  5. 7/8" Push on Retaining Rings
  6. 3D printed Clamp-On Pulleys
  • The 7/8" tube has the tube connecting nuts (star nuts) pressed into the ends of the length you need to span and is bolted into place on the ends acting as a standoff between two plates.
  • The needle bearings go in the ends of the polycarbonate tube after you cut it to length.
  • The push on retaining rings hold the tube and needle bearings in place.
  • The 3D printed pulley clamps over the polycarbonate tube so it can be driven by a belt.
  • Any rubber tube of your choice can be applied to the outside of the polycarbonate tube to provide grip on the game pieces.
Spectrum
Do you have any close up photos of how you made the hood more rigid? Thank you for these posts!
Quick question, how do clamp on pulleys work? Do you have a close up picture of the clamp on pulley separately?
More standoffs and aluminum ones, plus larger center ribs.
Just two parts, bolts and locknuts clamp it to the polycarbonate tube.
