4 Jags, 4 Victors. The Jags were upside down underneath the electronics board and powered the ‘twitch’ drive we had. We had zero issues running full foward to full reverse in less than a second when the twitch modules changed positions. We still used clear nail polish to keep the PWM’s though
This type of failure accounted for over 40% of all specific failure reports according to Luminary Micro so it is by no means unique.
The Jaguar Failure Analysis report can be found here
We used a mix of both. We found the Jags to definitely be smoother and more stable for low speed and position holding. A Victor on our turret drive would cause the turret to twitch with a tremor when trying to hold a position, and not be repeatable when homing to a position. The Jag in the same function would hold nice and steady, and repeat positions more accurately. We did however have a Jag fail on us at a critical time going into elims.
2502 used 4 Jags, no failures. They did seem pretty responsive on the low end of the spectrum for our brushes, and they did also allow very slow movement from the drive train which were both nice.
Victors for us. The Jaguars took up way too much space, and we didn’t need the control for our dumper. Didn’t need the hooks because we staple the wires down. The max current is 60 but our max breaker is 40. The limiter for keeping the motors from burning out isn’t needed because we limit the arm with programming. It is also a bit heavier than victors, which can add up.
Team 1245 used Victors, mainly because our Jaguars burned out. Victors have higer overall output, but Jaguars have a smoother control curve.
I really need to address a few things (misconceptions) here. The hooks referred to on the Jaguars (for the casual reader) are hold downs for the PWM control wires. (I assume that “stapling” indicates your robot used a wood electrical base. Generally staples are less than desirable as there is 5 volts and power common in the PWM cable and an errant staple could bring down your robot if it should short those two lines.
The max current specifications for the two controllers is based on the specifications of the FETs used and refers to the continuous current. (The Jaguar uses a FET that is slightly better in this regard) In both controllers and on our robots, current in CIM motors can achieve 129 amps in stall. There is nothing that limits that current, including the breakers (assuming wiring is not undersized or lengthy). The breakers will pass nearly 200 amps for short bursts without tripping.
The Jaguar has implementations that make it more linear at lower throttle values (primarily due to it’s higher switching frequency) and it has a slightly lower series “ON” resistance due to the FETs used. However, these differences may not be evident in your implementation. (For the price of a search, you will find a long discussion on this subject elsewhere on this forum)
For both controllers, full throttle means they are supplying the full battery voltage to the motor they are controlling. There is no modulation of the output at full throttle. The Jaguar does contain a small resistor that is used for current sense, it is equivalent to 6 inches of #10 wire. There is a voltage drop across this resistor that can limit the available supply voltage at higher currents and the current sense may cause the Jaguar to interrupt current flow for a short period of time.
I thought there was a teensy bit of time where the Jaguar output is shut off even when at a nominal 100% output. Something to do with recharging a capacitor that keeps it on? I suppose it doesn’t count as “modulation”, though.
This is true on the Grey Jaguars, but put emphasis on teensy. I’m not sure if it is true for Black Jaguars.
Alan,
You are correct but I discounted that short pulse as it is not under the control of the operators. From the Jaguar manual…
The MDL-BDC software intermittently switches to the low-side MOSFETs for a short duration to replenish the bootstrap capacitor. The short duration has no impact on motor speed.
We used 2 Jags for the drive motors. On the manipulator motors we used 5 Victors and 2 Spikes.
We used more Victors because we had them in stock from dismantling previous robots, so they where “free” in real money terms if not in cost accounting. And they took up less space.
We did have some issues with the Jags; one had the reverse only bug, but we replaced it and never had any more problems. We returned the bad Jag to Luminary, and they sent us a new one:)
