SpeedMotor converted to MotorController 2022
Hey,
I’m trying to import our robot’s framework lib and I got into some issues with the new MotorController convention…
Where pidWrite() go to?
SpeedMotor Once inherited from PID or something like that…
I need a method that will be called before each PID write in any motor controller
Maybe this wrapper class can implement that functionality: PIDMotorController (WPILib API 2022.1.1-rc-1-2-g22c4da1)
It does not exist for me :frowning:
I downloaded the “2022.1.1-rc-1” version so I could rewrite it as needed before the official release…/
But you are getting MotorController ? I am just asking to make sure you’ve updated the project to 2022. Sometime their are pains getting everything working.
I haven’t used PIDMotorController but since it is in the api on that rc it should be available to import. Make sure it is getting imported from pidwrappers I guess.
Yup…
IDK why,
I think something went wrong creating the project…
the REV vendor library also give me some troubles:
The supplied phased action failed with an exception.
Could not resolve all dependencies for configuration ‘:compileClasspath’.
Using insecure protocols with repositories, without explicit opt-in, is unsupported. Switch Maven repository ‘WPI3f48eb8c-50fe-43a6-9cb7-44c86353c4cb_0Release(http://www.revrobotics.com/content/sw/max/sdk/maven/)’ to redirect to a secure protocol (like HTTPS) or allow insecure protocols. See UrlArtifactRepository - Gradle DSL Version 7.3.3 for more details.
Going forwards, the SPARK MAX API has been replaced by REVLib: https://github.com/REVrobotics/REV-Software-Binaries/releases/tag/revlib-2022.0.0
Note that there will be a new version of REVLib coming out within the next couple of days.
PIDSource and PIDOutput were deprecated in 2020, and they’ll be removed in 2023. Just call the relevant getter directly and pass it into the PIDController, like so:
import com.revrobotics.CANSparkMax;
import edu.wpi.first.math.PIDController;
import edu.wpi.first.wpilibj.Encoder;
  private Encoder encoder = new Encoder(1, 2);
  private static final kDistancePerPulse = ...;
  private CANSparkMax motor = new CANSparkMax(0);
  private static final kP = ...;
  private PIDController controller = new PIDController(kP, 0.0, 0.0, 0.01);
  public Robot() {
    encoder.SetDistancePerPulse(kVelocityPerPulse);
    // Run controller every 10 ms
    addPeriodic(() -> {
      motor.setVoltage(controller.calculate(encoder.getRate()));
    }, 0.01);
  @Override
  public teleopPeriodic() {
    // Set the controller setpoint here
Don’t use those. They’ll be deprecated before final release:
Those wrapper classes are only used by the old command-based vendordep to make RobotBuilder old command-based output easier to implement, and they’ll be removed along with old PIDController and old command-based in 2023. We’re only keeping the old PIDController around because updating old command-based to the new PIDController would be wasted effort.
