Spike RED Pinout
I am using a Spike RED module for a project involving a demonstration, of electronic systems. I have searched everywhere, and haven’t been able to get the pinout of the control pins for the Spike RED. Does anyone know of where I could find the pinout, or does anyone have it?
Otherwise, Im going to try to determine it experimentally, assuming the black wire is ground. Does a 5V signal as a test input the control pins seem reasonable?
Try putting a multimeter on the output of the RC to test what kind of output is going to the Spike. I would say they are PWM, but those are the analog outputs on the other side.
Pin out is the same as the blue spike. Manual for blue spike is on Innovation First’s site. I only have a hard copy for the red spike. If there is any info you need let me know.
Andy, he was refering to the inputs from the RC, which the innovation FIRST manuals do not cover.
Venkatesh, you will find the answer in this thread: http://www.chiefdelphi.com/forums/showthread.php?s=&threadid=14026 When you first posted, I had remembered that thread, but couldn’t find it. Well, now I finally found it.
