Has anyone uses sprockets on their large CM motors
We mounted an extra transmission sprocket on the large CIM motor for the ball shooter, using a 5/16 transtorque and milling the sprocket bore to 3/4.
we plan to use a sprocket on one of our big CIMs too, though im not sure how it is attached.
We are and it’s pretty easy, depending on how much force they have to be able to take. Just drop a properly sized sprocket on it and tighten the set screw.
We took the shiv off of the large CIM, then hardened it. We then machined an aluminum disk shaped part and the inner diameter was bored out until the hardened shiv could be cold pressed in. This creates a perfectly mating coupling piece that a sprocket could be mounted to. No problems yet, even after stalling the motor.
