So I am using for the first time SRX mag encoders for the swerve and I need the offset position of each one. I know that i need to zero the wheels first but then where do I see the offset value?
btw i am connecting the encoders in the analog input
Offset is simply the difference between where it is and where it should be. So if you “zero” the wheels (i.e. move them to where you would normally expect the encoders to return 0), then read the value from the encoder (many ways to do this, ranging from reading in code and writing to smart dashboard/network tables/etc, to reading from the REV Hardware Client). This value will be your offset. Just repeat for each pod
Yeah yeah of course, but my problem is that i don’t know how to get the value, I am connecting the srx mag by an analog input so how do i record the value?
