Was wondering if any teams had any practical experience with how long it takes to destroy the various motors used in FRC when stalling?
For example have read here on cd 3-4 seconds for a 775 pro to release its smoke, and somewhere around 20-30 for a cim. What about mini cim, bag motors and so on?
You shouldn’t plan on doing this often. The bag and cim motors don’t have any good way of transferring heat out of the rotor, so they’re going to stay good and hot for quite some time after that. Also those tests start with the motor cold. If you’ve been running the motor previously, it’ll be rather warmer to start with.
I agree with your conclusion, but heatsinks are not a reason. Heatsinks help only marginally in a stall situation where the rotor is heating rapidly. The rotor has no good thermal path to the case of the motor.
Please remember that motor testing is done with a well regulated and high current power supply at a constant 12 volts. Your mileage will vary from that. Also remember that while there is very high heat generated within the rotor of the motor during stall, the failure comes from the breakdown of the insulation on the wire in the rotor. Some motors have lower temperature failure on the insulation than others. Some motors do not adequately insulate the rotor and so high temps result in the windings shorting to the motor frame.
