I’m getting this error in the driver station. does anyone know what this is about I can’t fix it.
ERROR 1 Unhandled exception: java.lang.NullPointerException frc.robot.subsystems.DriveTrain.<init>(DriveTrain.java:20)
ERROR 1 The startCompetition() method (or methods called by it) should have handled the exception above.
this is my drive train:
package frc.robot.subsystems;
import com.revrobotics.CANSparkMax;
import com.revrobotics.RelativeEncoder;
import com.revrobotics.SparkMaxPIDController;
import edu.wpi.first.wpilibj.ADXRS450_Gyro;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import frc.robot.Constants;
public class DriveTrain extends SubsystemBase {
CANSparkMax leftLeader;
CANSparkMax rightLeader;
CANSparkMax leftFollower;
CANSparkMax rightFollower;
RelativeEncoder leftEncoder = leftLeader.getEncoder();
RelativeEncoder rightEncoder = rightLeader.getEncoder();
SparkMaxPIDController leftController = leftLeader.getPIDController();
SparkMaxPIDController rightController = rightLeader.getPIDController();
DifferentialDrive drive = new DifferentialDrive(leftLeader, rightLeader);
ADXRS450_Gyro gyro = new ADXRS450_Gyro();
double setpoint;
double leftEncoderPosition;
double rightEncoderPosition;
public DriveTrain() {
leftFollower.follow(leftLeader);
rightFollower.follow(rightLeader);
gyro.reset();
gyro.calibrate();
leftController.setP(Constants.kP);
leftController.setI(Constants.kI);
leftController.setD(Constants.kD);
rightController.setP(Constants.kP);
rightController.setI(Constants.kI);
rightController.setD(Constants.kD);
leftController.setOutputRange(-1, 1);
rightController.setOutputRange(-1, 1);
public void drive(double f, double t) {
drive.arcadeDrive(f, t);
public void drivePID(double s) {
setpoint = s;
leftController.setReference(setpoint, CANSparkMax.ControlType.kPosition);
rightController.setReference(setpoint, CANSparkMax.ControlType.kPosition);
drive.feed();
public void angleCorrect(double angle) {
if (gyro.getAngle() < angle) {
drive.arcadeDrive(0, 0.5);
} else if (gyro.getAngle() > angle) {
drive.arcadeDrive(0, -0.5);
public void resetGyro() {
gyro.reset();
public void calibrateGyro() {
gyro.calibrate();
public boolean leftAtSetpoint() {
if ((leftEncoderPosition == Math.abs(setpoint + 2)) || (leftEncoderPosition == Math.abs(setpoint - 2))) {
return true;
} else {
return false;
public boolean rightAtSetpoint() {
if ((rightEncoderPosition == setpoint + 2) || (rightEncoderPosition == setpoint - 2)) {
return true;
} else {
return false;
public double getleftVelocity() {
return leftEncoder.getVelocity();
public double getRightVelocity() {
return rightEncoder.getVelocity();
public double getVelocity() {
return (getleftVelocity() + getRightVelocity()) / 2;
public boolean atSetpoint() {
if (leftAtSetpoint() && rightAtSetpoint()) {
return true;
} else {
return false;
public void update() {
leftEncoderPosition = leftEncoder.getPosition();
rightEncoderPosition = rightEncoder.getPosition();
