Is anyone else having trouble starting shuffleboard directly from the driver station. We found we need to execute the jar file directly in order to get it to start.
We had this happen on one student’s laptop, not sure what the actual issue is or how to fix it.
This documentation may help: https://wpilib.screenstepslive.com/s/currentCS/m/driver_station/l/290135-manually-setting-the-driver-station-to-start-smartdashboard
Just configure it to point at the Shuffleboard jar instead of SmartDashboard.
Do you have multiple versions of Java installed? The DS may be using an incompatible version. You can use the java uninstall tool: https://www.java.com/en/download/uninstalltool.jsp
